Hey guys got a question about my 95 325is (m50tu). car makes a chirping noise at idle, 1st gear, reverse that goes away at higher rpms. I've replaced both belt tensioner pulley bearings and belts with no change. My m50 uses a mechanical belt tensioner for the wp/fan/ps/alt belt and does not use the idler pulley found on many m50s.
looks like this:
Using a mechanic's stethoscope i think ive narrowed it down to the belt tensioner as it sounds like something is banging around inside the housing through my ear pieces.
has anyone ever had to replace the belt tensioner on their 24v due to noise?
looks like this:
