Rad support and skid plate mods
  • chrisbmx68
    • 358
    Broke a m42 oilpan and motor mount tab off my sub frame earlier in the summer with a skid plate, it mostly just bent my front radiator support in so the pan was almost touching. I decided to improve the mounting situation and the strength of the plate itself during my 24v swap.
    2x3 tube for the lower rad support
    .5x.5 tube for the skid plate
    I can jack the car up on the plate now with minimal deflection. The front edge of the plate had to be bent and additional holes drilled.
    Bent up some 1/2in tube to reinforce the plate as best as possible after the motor was mounted.
    tigged it all in
    this is an m42 skid plate, the m50 pan sits nicely between the bracing about 1/4in away from the plate.
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Nice, that should give lots of protection.
    • M3PO
      • May 2012
      • 537
      Looks good! I am planning to get a Peerless skid plate in case I go off the track...
      • chrisbmx68
        • 358
        the peerless unit is definitely more robust, I would have got that if I hadn't already had a race skids one. My only gripe with his is that the reinforcement strips are on the bottom side.
