s52-e30m3 wiring questions
  • travis816
    • 828
    This is the wiring diagram from www.e30dohc.com. I have an 88m3. I was wondering if this is the same chassis harness and the m3. If not, where i go about finding one. I do not have a m3 cluster. Standard 90' 6 cyliner cluster. Thanks in advance. Travis
    Chart showing pin arrangement when swapping e36 motor into e30 chassis.
    From Pin # For To Pin #
    '86-91 325 '92+ 325i, M3
    1 Alternator charging 25
    2 Not used
    3 Not used
    4 Coolant temperature sender 12
    5 Oil pressure 23
    6 Not used
    7 Ignition switch 21
    8 Fuel rate 24
    9 Engine Speed 20
    10 Not used
    11 Diagnostic connector 19
    12 Check engine light control 8
    13 Fuel pump relay 13
    14 Oil level fault set 14
    15 Starter motor 15
    16 Not used
    17 Not used
    18 Starter 18
    19 Oil temp X6031 pin 10
    20 Coolant temp 11
    In some 86-87 models, Speed output is
    C104 under glove box Engine speed output, BK/BU Tach 20
    88' m3
    91' 318is
