So I I finally have everything together but when I went to start the car the starter spun without engaging. I saw that there was another thread with the same problem that I am having but when I shorted the starter solenoid it did pop out and engage but when I wire everything back up it now only engages and won't spin. So I don't think the starter is bad since I can get it to both spin and engage. Just not at the same time :(
The other strange part to the story is that when I turn the key to on, the coolant gauge flips to red, then when turn the key to start the gauge drops to zero and then goes back to red when I stop cranking. Any ideas why the coolant sensor would be seeing a voltage drop like this?
Here is my starter wiring and my adaptor wiring, seems like it is wired correctly for the starter circuit. This is a 92 m50nv going into an 87 325e.
