You need to shorten and thread the 944 booster input rod, but it is the same thread diameter and pitch as the E30 clevis.
DIY: In depth M52/S52 OBD2 swap
Originally posted by FredK View PostYou need to shorten and thread the 944 booster input rod, but it is the same thread diameter and pitch as the E30 clevis.Originally posted by blunttechAlways Always go for the reach around if there is an option
thanksYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
1998 BMW Estoril Blue e36 M3/4/5 SOLD
1987 BMW 325 (The Piece) SOLD
1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
Added some tips for dropping the engine in.
Can you guys think of any more?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Originally posted by Stitche30 View PostIf you use the g240 transmission can you retain original drive shaft?
Honestly I'd fork up some more cash for a stronger transmissionYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
:) WOOOOOO!!
1989 BMW 325i SOLD
Originally posted by surebimmer View PostNice job. You going to get this bar'd?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Any reason you couldn't follow the same procedure here for the most part in doing an OBD2 M54 swap?
If unnecessary functions like EWS and emissions junk, etc can be deleted from the M52/S52 ECU why can't the same be done for the M54?
Hopefully some of the tuners like TRM and DesertBMW can comment on this...Zinno '89 <24v swap in progress>
Originally posted by chris_rai View Postare you using e28 mounts ? i'm wondering how the mount is sitting on the driver side, mine will not sit flat on the subframe, looks like the angle will not allow it !
let me know
thans
Not sure what your problem might be. Maybe try mounting in a different hole on the subframe?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
