DIY: In depth M52/S52 OBD2 swap
1989 BMW 325i SOLD
1998 BMW Estoril Blue e36 M3/4/5 SOLD
1987 BMW 325 (The Piece) SOLD
1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
Originally posted by maniacmatt View PostI mean the universal OBDII connector usually found under the dash on OBDII cars. Like this.
How and where are you guys wiring and mounting it?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Originally posted by maniacmatt View PostAnother question. For those running the M50 intake manifold. What throttle body do you pair with it? OBDI or OBDII? Or does it matter and why?
Thanks again.
I believe it is also fairly easy to run the obd1 TB.
There is TONS and TONS of info about m50 manifold conversions. Quick google search will give you any answer you needYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Originally posted by e30serg View PostNice thread! I see you're in the SF bay too....are going to get t BAR'ed?
Originally posted by ZekeTheSneak View PostI want to hear your completed exhaust soon, I want to go the same route
It sounds awesome! Better in person than the vidsYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
I found out that this worked awhile ago and since I have contacts in VW/AUDI, I got this brake booster and MC for dirt cheap. It bolts right up to the firewall. 2 bolts instead of 4 in a cross pattern. It holds perfectly.
All that needs to be done is cut the AUDI brake booster push rod and rethread the E30 clevis. Here how it looks. This is my bay.
Originally posted by mtlbloodshot View PostI found out that this worked awhile ago and since I have contacts in VW/AUDI, I got this brake booster and MC for dirt cheap. It bolts right up to the firewall. 2 bolts instead of 4 in a cross pattern. It holds perfectly.
1989 BMW 325i SOLD
Originally posted by Link View PostGreat write up.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
So I used a e32 dual chamber and MC.Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.
Originally posted by Mr.SWISS View PostIs that the A4 1.8T booster? I was going to go this route as well since you can use the res it includes instead of a remote res but the seller couldn't find the booster after I won the auction someone scrapped it!!
