I just recently discovered that when you convert an OBD II engine to OBD I, you either get the OBD I wiring support with the metal bracket for the ICV, or you end up with the ICV hanging by the hoses and eventually shearing them. This leads to a vacuum leak which you weren't expecting, so you spend the best part of two days cleaning the MAF, the throttle body etc. before you take the ICV out and realise the hose is in three pieces. You then swear loudly at the mechanic who did the swap and decide you want a bracket. While you're there, you extend the bracket so that it holds the E34 oil dipstick as well. They will both get bolted to the manifold support, which already has two very handy bolt holes.
I finished the aluminium prototype and I'm about to have a small run made. Is there any interest or does everyone just buy the OBD I part from BMW?
