S52 OBD2 Rough idle and other weird issues
  • craiggroves91
    • Oct 2009
    • 3024
    Hey, so I'm running an OBD2 S52 with the M50 manifold and m50 fuel rail and the car when first fired up idled well and sounded great as seen in the video posted below.
    Car specs
    OBD2 S52
    Flashed Siemens ECU with necessary deleted systems
    Wiring harness modified by Dave@markert
    M50 intake manifold w/m50 fuel rail and S52 Throttle body
    Car was run open exhaust manifold and intake in the vids later tried a MAF with no difference
    After the video was shot we weren't able to fire up the engine again, then after messing with it for awhile I finally got it to fire up again, but this time it was much different than in the video.
    It was missing, poor idle, and occasionally on startup would scare the living shit out of me and go WOT all by itself.
    What could the problem be? Its odd that the car could go from idling well to having these issues.
    If, needed ill try to get a video of it now
    could this have anything to do with the 8+ month old gas in it? should I drain it and fill it up with fresh stuff? doesn't really make sense since it was the same gas used when the engine idled well
    thanks
    -Craig
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • pandaboo911
    • 2070
    Where's the MAF?
    • craiggroves91
      • Oct 2009
      • 3024
      Originally posted by pandaboo911
      Where's the MAF?
      Doesn't need a MAF to run
      The MAF plug only takes OBD1 MAF's so I have to figure out whats going on there
      1989 BMW 325i SOLD
      • craiggroves91
        • Oct 2009
        • 3024
        bump
        1989 BMW 325i SOLD
        • craiggroves91
          • Oct 2009
          • 3024
          PROBLEM SOLVED! Bad and nearly empty tank of gas = unhappy s52
          Don't make stupid mistakes people!
          1989 BMW 325i SOLD
          • 328ijunkie
            • May 2007
            • 3961
            ^Love it when that happens.
            Check Us out on Facebook
            Full Product Line Tuning
