m42 radiator troubles
  • dmjensen
    • Jan 2011
    • 805
    To those of you with an 24v swap and an m42 radiator, how did you bleed the system?
    Im having difficultys trying to bleed my s52 that i just added a new m42 radiator. I used a vac system to suck the coolant in ( so tenically i shouldnt even have to bleed it) but when i let it run the temp starting climbing and it was steaming pretty good. I took off the upper hose and got no coolant out but just steam. Is there a better way to do this or am i missing somthing?
  • jeffmn8
    • Jul 2010
    • 217
    Raise the front, turn the heater on full blast, run it and squeeze the crap out of the hoses.
    Worked for me multiple times.
    Midwest Spec E30 #64
    https://www.facebook.com/thestickergarage
    • dmjensen
      • Jan 2011
      • 805
      I didnt raise the front so im sure thats whats got everything so messed up
      • butters
        • 1202
        This topic is beaten to death, searching should yield hours of threads to review.
        Raising the front or parking on an incline helps. I never got what was so troubling, run the engine, crack the bleeder screw and fill until bubbles stop coming out of it. Bleed screw - it serves its purpose.
        • dmjensen
          • Jan 2011
          • 805
          dude, unless I'm an idiot (which sometimes i think so) there is not a bleeder screw on an s52 lol. i know there's one on an m20 yes, but not an s52.
          also, i raised the front of the car and tried again and it hasn't gotten past half way on the gauge yet so it worked! :up:
          • dontrusthise30
            • 59
            Bleeder screw is on the radiator next to the cap.
            • Ryann
              • 3350
              Coolant quantity will be different for you, but this works perfectly and instantly every single time.
              • butters
                • 1202
                I never had an M20 so I didn't realize the confusion haha. Glad you got it sorted though (hopefully).
