flywheel/clutch opinions
  • bimmer630
    • 1228
    Im looking at this http://www.ebay.com/itm/SACHS-CLUTCH...ht_3902wt_1186
    Swap will be S50 with G260.. All I need to make this clutch work with the E30 trans is the m20 pilot bearing in the s50 crank right?
    I tried searching this specific topic to no avail... I might be worrying too much about it because the E30 swap wiki makes no statement about flywheels and clutches, so maybe you can use anything you want? (I did find the m20 flywheel needs to be machined on the back side.. )
    I want a performance lightweight flywheel.. I figure if I have it all apart I might as well upgrade
  • blackhawkimpact
    • 2415
    Yes. You use the m20 pilot bearing
