Late S52 temperature sensor question
  • TheRealE30kidd
    • Jul 2010
    • 496
    Late S52 with one temp sensor. Want to use the E30 temp sensor. Obviously it's 2mm bigger than the existing hole. The motor is complete, so I am a little nervous about running a tap on it. Should I tap the head or rethread the temp switch. I'm leaning towards tapping the head but i'm not 100%.
    So R3v, what do you suggest I do?
    The Current Army
    -(UnderConstruction) 1991 330iS 24v S52 build thread
    -1992 325iC
    -1987 E30 Truck
    -1991 332iS (BecauseRacecar)
    -1988 Dinan M3
    -1988 325iX Tribute car
    -1989 320i Touring (S52/6spd)
  • 7pilot
    • 475
    Re-thread the sender.
    12mmx1, iirc.
    m
    • Gooch
      • Dec 2006
      • 1674
      It is 12x1.5. (Napa part number 55851 if you don't have a kit and need just the one die).
      '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
      '87 535i - Vacuum brake conversion [SOLD]
      '93 525iT - 5-speed swap - 320k and counting
      '09 328xi - 6-speed
      • 328ijunkie
        • May 2007
        • 3961
        The page you're looking for does not exist. Please visit our home page or locations page for more information.
        ;) P&P :P
        Check Us out on Facebook
        Full Product Line Tuning
        • SwiftE30
          • Jun 2010
          • 998
          tap the sender for sure. Took about 20min and fit perfectly.
          1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
          • TheRealE30kidd
            • Jul 2010
            • 496
            Took a file and filed off the threads then re taps it 30 mins not bad at all!
            The Current Army
            -1992 325iC
            -1987 E30 Truck
            -1988 Dinan M3
            • Evil-E
              • Aug 2012
              • 20
              This^
              That way if you mess up on the threading it's only a $15 part as opposed to the head. Also if you ever decided to sell the S52 the sender hole isn't oversized for a potential buyer who isn't swapping it etc.
