Fuel pump relay buzzing
  • Cyrix2k
    • 593
    I'm trying to diagnose my '91 e30 that has a full '92 M50NV swap. The fuel pump wasn't turning on with the key when I got the car but it turns out the harness adapter had a faulty connection for the fuel pump relay. I fixed that and now the fuel pump relay makes a buzzing sound (it's rapidly turning on and off) - that can't be normal can it? I've tried two ecus (a red label and a blue label) that came with the car, but I have access to a third, known working red label that I can also try after I verify there are no more wiring faults. Anyway, do you guys have any ideas as to what would cause the FP relay to buzz?
    P.S. I sincerely doubt this has anything to do with the leak.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
  • Cyrix2k
    • 593
    Update: is it supposed to buzz? because the car runs...
    1997 540i/6 - stock
    • Todd Black 88
      • Oct 2007
      • 3449
      Measure the voltage at the coil of the relay. If its below spec, find the wiring issue causing the voltage drop. If its within spec, replace the relay.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
