S52 w/ ZF 5 speed Reverse lights
  • craiggroves91
    • Oct 2009
    • 3024
    So after searching around I can't get solid info on how to get reverse lights working.
    Do I use an e30 reverse light switch and screw that into the ZF and use the factory e30 wiring that goes through the shifter?
    thanks
    -Craig
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • bmwdready347
    • Jan 2011
    • 586
    if your car is already stick shift u just take the two wires that run threw the boot to the the tranny and u have to plug the wires up to the e36 tranny it is two wires and they will work with no modification
    • bmwdready347
      • Jan 2011
      • 586
      and use the zf reverse light switch
      • craiggroves91
        • Oct 2009
        • 3024
        The ZF has a plug type switch though?
        1989 BMW 325i SOLD
        • Todd Black 88
          • Oct 2007
          • 3449
          The two switches are exactly the same, but the e36 one uses a plug style and the e30 is just two connectors.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • craiggroves91
            • Oct 2009
            • 3024
            I got them working. Just used the running losses plug I snipped off the e36 harness and wired it in to the factory e30 wiring.
            1989 BMW 325i SOLD
            • 328ijunkie
              • May 2007
              • 3961
              ^that works lol
              Check Us out on Facebook
              Full Product Line Tuning
              • nmlss2006
                • 910
                ..running losses?
                • craiggroves91
                  • Oct 2009
                  • 3024
                  Originally posted by nmlss2006
                  ..running losses?
                  It's a valve/solenoid type thing on OBD2 cars that has to do with fueling I believe?
                  Not sure exactly, but basically you just want any BMW two prong plug that will slide onto the reverse plug on the trans
                  1989 BMW 325i SOLD
                  • yahh
                    • Aug 2012
                    • 800
                    Is there a way to check if its the switch or the body side wiring? Can i jump the wiring in some way? I put the e36 connector onto the e30 wiring . I tried switching the wires and fuse #10 and still no reverse lights. Bulbs look good too. Any ideas?
                    s50 86 325e Project
                    S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
                    Feedback Thread
                    • e30rapidic
                      • 2167
                      yeah, just jump the two wires together that lead in to the switch and see if the reverse lights come on.
                      '87 325ic, powered by S50.
                      • yahh
                        • Aug 2012
                        • 800
                        Yeah I got it figured out. The green wire was torn inside the but the cover wasn't. Rewired it and it works now. Always something dumb.
                        s50 86 325e Project
                        Feedback Thread
                        • jjc034
                          • May 2018
                          • 107
                          My reverse lights aren't working so I checked Fuse #10 and all was good, and I also tried jumping the connector under the shift boot and that didn't trigger the reverse lights either.
                          I did install a keyless entry in the trunk of the car, but I recall the reverse lights not working before then.
                          I hear some people had to extend the switch - is that the next step? Pull the switch and see if pushing it in will trigger the reverse light?
                          What else should I be looking for?
                          Thanks,
                          John
                          • wilholl
                            • May 2012
                            • 518
                            Might be a dumb question... but if you jumped the connector under the shift boot and the lights still did not work, wouldn't that rule out the switch as the problem?
                            Is there voltage at the connector under the boot?
                            1988 325 non-letter Seta "Bronzit"
                            1991 325ic "Laguna Green" (Sold)
                            1993 325i "Laguna Green/Silver" (Sold)
                            1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                            2000 528i Titansilber/gray m-sport
                            2000 528i Titansilber/black m-sport(sold)
                            2001 525i Anthracite m-sport(sold)
                            2013 750i Black/Black m-sport "Beast"
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              Thanks,
                              John
                              If you jumped the car side and the lights didn’t come on, then changing the switch will do nothing. Change the fuse, whether it looks good or not, and try it.
                              If you jumped the transmission side of the plug.....smack yourself..
                              2010 F650gs twin
