wont rev past 4k!!
  • JayGotti
    • Jul 2012
    • 200
    wont rev past 4k!!
    yea so my buddy has a e34 m50 single vanos and it doesnt past 4k under load. and revs to redline in neutral. ive read that it could be the cps but he replaced it and tht wasnt the problem. he also has a little leak on the manifold on the second piston area, could that be the cause of not revving past 4k under load?
  • evandael
    • Oct 2009
    • 2881
    did he wire up the VSS?
    • JayGotti
      • Jul 2012
      • 200
      what is vvs?
      • JayGotti
        • Jul 2012
        • 200
        Originally posted by JayGotti
        what is vvs?
        you think the speed sensor could cause this?
        • evandael
          • Oct 2009
          • 2881
          VSS is the vehicle speed signal. the M50's DME needs to see a road speed before it will allow it to rev past a certain RPM.
          i forget the c101 and x20 pin #'s but IIRC, this is a common cause for his issue.
          • future rs
            • Aug 2012
            • 514
            Sounds like he is R3v limited...
            • AlpineM325
              • Aug 2007
              • 373
              Haha that it seems.
              WTB
              -convertible carpet, no rips, in socal.
              -s52, s50, m52, m54
              -harness, accessories, transmission
              • JayGotti
                • Jul 2012
                • 200
                i have a 413 dme and if the vss doesnt work will the speedo work?
                • e30rapidic
                  • 2167
                  vehicle speed sensor
                  ecu needs a signal from the back of the cluster. Lots of info on here regarding it
                  '87 325ic, powered by S50.
                  • JayGotti
                    • Jul 2012
                    • 200
                    i was in his car trying to help him trouble shoot it and it basically acts like a 2step in gear. sometimes it passes 4k in first gear to like 5.5k, and sometimes in neutral it goes to redline and sometimes it does the 2step at 6 or 7k.
                    • JayGotti
                      • Jul 2012
                      • 200
                      the signals from the c104 connector goes to the harness, are those 2 wires the vss? both tach and speedo work
                      • graphikg
                        • Jan 2008
                        • 1614
                        Try disconnecting the vanos from the harness and driving it under load. If that allows the car to go past 4k, then it is Vanos and timing perhaps.
                        • JayGotti
                          • Jul 2012
                          • 200
                          found the problem it was the vss thanks guys!!
                          • MaxBell
                            • 1391
                            Can you please post what you did to hook up the VSS? I heard it being said in various places and no one ever gives a SPECIFIC wiring tutorial.
                            What wire (color, location) did you start at? Which wire (color, location) did you connect to?
                            EDIT: Ok I got serious and pulled the wiring diagrams and things for my early model with a 1995 M50 in it.
                            Here you all go: http://www.r3vlimited.com/board/show...23#post3459423
                            REMEMBER: Be safe and have fun is Rule Number 1.
                            The Epic Unbuild of Clint Eastwood
                            • evandael
                              • Oct 2009
                              • 2881
                              what joy, a happy ending.
