M50nv stroker - what can i use?
  • wakdog
    • 223
    So after my cam install and chain tensioner failure (and a bunch of bent exhaust valves), I have found that the pistons in the motor look pretty sad (something has been sucked through the motor and into cyl 1 and 6 in the past - big scores on the edges of the top of the pistons...)
    Speaking with my mechanic, I have access to many parts from m52/m54 motors that we might be able to use, my first questions was - is it possible to use M52B28 Crank/rods/pistons in my NV block with NV head?
    Other option is M54B30 rotating assembly, is there anything I can use from this (i know that the crank is the same as S52...)
    Basically id love to be able to take advantage of an parts I have access to rather than just putting back together a 2.5...
    90 318i M62B44 OBD1
    02 530i Touring (Airlift 3P)
  • DesertBMW
    • Aug 2011
    • 1040
    you can use both the 2.8L and 3.0L rotating parts in your 1992 NV engine, no other modifications required, other than modding the oil baffle. stock ecu will work fine.
