About to make huge part order, anything i need/dont?
  • Pettas
    • Dec 2004
    • 41
    I am about to make a huge part order from Autohausaz (Local to me). Please tell me if there is anything I need/dont need in this section.
    11531738053 Metzeler
    Cooling/Coolant Hose; 4-Way Hose from Block to Heater Outlet $62.08 $85.50
    Remove $62.08
    64211394292 Elaplast/CRP-Continental
    Cooling/Coolant Hose; Heater Valve to Right Side of Heater Core $9.95 $16.00
    Remove $9.95
    11811132793 Metzeler/CRP-Continental
    Engine/Motor Mount; Left/Right; Heavy Duty $37.28 $42.00
    Remove $74.56
    13641286708 DPH/CRP-Continental
    Fuel Injector Seal; 7.8x3.6mm $0.64 $2.95
    Remove $7.68
    11611717259 VictorReinz
    Intake Manifold Gasket; Intake Manifold to Cylinder Head $2.37 $9.30
    Remove $14.22
    11421730389 Mahle
    Oil Filter Kit $5.46 $9.98
    Remove $5.46
    11131437237 Bruss/VictorReinz
    Oil Pan Gasket; Rubber/Metal $19.95 $32.00
    Remove $19.95
    17111469179 Nissens
    Radiator $146.80 $323.00
    Remove $146.80
    11531726344 Elaplast/CRP-Continental
    Radiator Hose; Lower Radiator to Thermostat Housing $9.60 $33.25
    Remove $9.60
    11531720722 Elaplast/CRP-Continental
    Radiator Hose; Upper Radiator to Thermostat Housing $8.76 $18.80
    Remove $8.76
    035121119 VictorReinz
    Thermostat Gasket/Seal; 60x3.5mm $0.33 $1.10
    Remove $0.33
    11531740437 Goetze
    Thermostat Gasket/Seal; For Thermostat Housing $0.46 $1.38
    Remove $0.46
    11531722531 MTC/German (OES)
    Thermostat Housing/Water Outlet; Aluminum Update Replacement $21.09 $32.25
    Remove $21.09
    11531721002 Behr/Wahler
    Thermostat; 88 Degree C $16.76 $34.00
    Remove $16.76
    11511722536Z Graf
    Water Pump; Update Replacement wtih Metal Impeller and Gasket $59.07 $96.75
    Remove $59.07
    I am not doing the head gasket, but as you can tell, I am doing a lot of other gaskets, etc...My valve cover gasket has already been checked, and I am not sure if I am going to be able to get m52/s52 manifolds or have to stick with m50 ones, so I am not purchasing the gaskets for that yet.
  • Dave
    E30 RAT
    • 11675
    Don't get that Graf waterpump. I have had 2 defective ones. Get the one from the dealer.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • Pettas
      • Dec 2004
      • 41
      You know the price on the dealership one by any chance?
      • Jason89i
        • Sep 2004
        • 875
        are you talking about the exhaust manifolds? you will want the m50 exhaust manifold gaskets either way......there is no hole in the gasket for the air pump that the obd2 cars require.
        dont forget to reseal your trans and engine....MUCH easier now.
        rear engine crank seal (common leak spot.)
        front engine crank seal
        trans input seal
        trans output seal (common leak spot.)
        trans shift selector rod seal (called a shaft seal, common leak spot)
        jason
        • Pettas
          • Dec 2004
          • 41
          Oh, thought I read last night someone posted what exhaust gaskets to use with the m52 headers. They said to go with the m52 gaskets from what I believe.
          • permit
            • Mar 2005
            • 3363
            Edit: read wrong.
            You need the holes on the manifolds welded up and machined down so its a flat surface. You can use the M52 gaskets...you're using M52 manifolds. Aren't the M50 ones smaller, anyways?
            • Pettas
              • Dec 2004
              • 41
              Ok, I wasnt sure on that. Thought the m52 ones were bigger in diameter, and thus i would need gaskets to make it even. Ive known about the holes in them, and ill get that taken care of as well. Thanks
              • Jason89i
                • Sep 2004
                • 875
                Originally posted by permit
                Edit: read wrong.
                head castings for the m52/s52/m50/s50 are identical except for the temp sender. i have used m52 tube headers w/ m50 gaskets. the gaskets are nearly identical except for the air pump hole. yes you should weld a plug on the air pump hole .....or cut off the tubing and weld that shut as the easy route.
                cheers, jason
                • FredK
                  • 14761
                  $71 is pretty much the lowest you're gonna get the Geniune BMW waterpump. Check out bfbmw.com, or get BMA Parts to order a genuine one for you. I got mine from BMA.
                  The OE part has a composite blade, unlike the Graf or Geba which have cast impellers, that put a good amount of strain on the bearings, which usually causes premature failure.
                  • 1990m3
                    • 1180
                    so should it be M50 or M52 exhaust gaskets on S50 with S52 headers? I should start writing this stuff down
                    • permit
                      • Mar 2005
                      • 3363
                      M50/S50 gaskets on any manifold you use.
                      • 1990m3
                        • 1180
                        now the info is conflicting...
                        hmmm...
                        • permit
                          • Mar 2005
                          • 3363
                          What I just posted is the correct info. Anything before was a lie or correct, but we were in the debating stages so it was confusing to read.
                          • 1990m3
                            • 1180
                            I say conflicting because I started a thread about the gaskets 3 das ago and got a different answer:
                            • 325Projectz
                              • Jan 2005
                              • 1956
                              Either one will work.
                              S50 3 need
                              S52 2 need
                              91 m3
