M52 hp?
    M52 hp?
    Trying to find out how much HP a M52 will make in a E30 with some minor mods. Rough estimation. Can someone help me?
    - M52
    - 21.5 LBS/HR INJECTORS
    - S52 CAMS
    - ODB1 (intake manifold / MAF / fuel rail )
    - TRM TUNE
    - Stock M52 HEADERS
    MY BUILD THREAD
    http://www.r3vlimited.com/board/showthread.php?t=235231
    INSTAGRAM : @luchcolaneri
    also interested in this. running the same thing.
    from what ive seen its usually 200-210 but id be interested to see dyno charts and actual number.
    www.cp-e.com
    1989 Zinno 325i m52 turbo coupe
    2015 Ford Fiesta ST, Daily Driver.
      They mention that just with S50 OR S52 cams (assuming a tune) will provide 200 WHP.
      I dunno how much or if the the odb1 conversion adds any power.
      MY BUILD THREAD
        I have this exact setup and have read it should be somewhere around 210-220 whp. I haven't dyno'ed mine yet so I don't know the exact number I'm getting.
          Originally posted by mtlbloodshot View Post
          http://www.e30dohc.com/wiki/index.ph..._Basics#M52B28
          The obd-1 manifold is good for 15-20 peak hp, at the loss of low end torque.
            with those numbers it seems like a great alternative to the s50/52 considering the m52 is generally half the price.
            www.cp-e.com
              I dynoed 194 hp and 177 ft lbs with everything you listed above except stock m52 cams. My friend with his e36 328is and same exact setup listed above, made 217 whp with s52 cams
              ^M52B28^
                mine did 210whp with bad tune, aiming for 230+ when properly tuned.
                m50b28 (m50tu block and pistons with m52 crank and rods)
                21.5#
                s50 cams
                ebay longtube headers
                  So if the average is between 210-220 WHP.. What would that translate into it HP?
                  I read that from the crank there is a average 18-25 % loss to the wheels with a RWD.
                  MY BUILD THREAD
                    crank would be 250-260, but bhp is a pretty meaningless number
