What flywheel should I run??..
  • bimmer630
    • 1228
    89 E30
    93 325is (i know this is dual mass)
    ..are they both dual mass ?
    my trans makes alot of gear rattle making me think theres no dual mass in there.
    basically whats the best flywheel and clutch setup to run? I have both.. but the E36 starter is no good
    • 37829
    89 E30 would have to be a M20B25 car. They have a single mass flywheel which many people run with 24v swaps.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Blaine0002
      • 382
      With the e30 flywheel you need to get the engine side machined down.
      I took mine down to 1/16" above the ring gear, this way it will mate to the m50, work with a g260, and it will be a bit lighter.
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        ^thats what i did too.
        -Andy
        • bimmer630
          • 1228
          sweet. I have a machinist friend.. And an M20 starter that still works lol
          • bimmer630
            • 1228
            Are the clutches basically the same between both setups? And is it possible to use the m5 (e28) clutch on the m20 flywheel? I'd like to find a low budget stronger clutch option
            • Unearth078
              • May 2008
              • 2623
              Why dont you just run the entire g260? you literally will bolt up the same flywheel clutch and pressure plate. using the same tob and fork.
              dont know about your higher HP option.
              Originally posted by Lof8
              4 doors allow you to transport more whores.
              therefore, their value is much greater.
              Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
              • bimmer630
                • 1228
                I am running the g260 with m20 flywheel.. just wondering if there's a beefier clutch I can throw on there cheep
                • brenE30
                  • Aug 2009
                  • 120
                  im pretty certain you can have the 260 flywheel shaved down to about 13lbs, as apposed to the stock 17lbs, might be off a pound or so(someone correct me) stock m20 clutch is more then enough to handle the power. im doing a s50 now and running all stock 260 stuff flywheel back
                  • bimmer630
                    • 1228
                    Ive had my stock clutch slip on me (granted when screwing around.. rolling down a hill then dumping the clutch in a burnout attempt).. sometimes it seems like its a tad weak.. its not worn out either
                    • SwiftE30
                      • Jun 2010
                      • 998
                      I'm using a south bend stage 3 clutch with the stock s52 dual mass flywheel ad I love it! Not sure what your end goal is for HP but I would recommend this for anything over 250 I guess.
                      1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                      • Bimmerguy91
                        • Jul 2012
                        • 982
                        Im running a lightened m20 flywheel and m20 starter with zf310 tranny
                        • amcink
                          • 788
                          subscribed - preparing stuff for my swap M50NV
                          • Blaine0002
                            • 382
                            I grabbed an f1 racing stage 3 clutch off ebay. Its noted that it should work with both m50 and m20 depending what transmission and pilot bearing combination you want. If you want more horsepower out of it, id go with the ZF. Would probably be the best in the long run, but you wouldnt be able to use your stock e30 driveshaft.
                            • Blaine0002
                              • 382
                              http://www.ebay.com/itm/F1RACING-STA...c4d8ca&vxp=mtr
                              Linky poo
