emissions delete questions
  • hooken m
    • 1537
    hey guys whats going on, so im still trying to finish up my s50 swap before i freeze my nuts off and i want to get rid of any and all emissions things i can get rid of for less hoses and line and whatnot. idc about emissions since im not running cats anyways. so i'd like to know what can i delete and what needs to be plugged, etc?
    also i'd like to know if there are any coolant hoses that i can delete. ive seen a few instances of people not running their throttle body hoses? is that correct? anything else?
    thanks alot
    -Amin
    Originally posted by evandael
    a car is a car. call it a dildo, i'd still drive the hell out of it.
  • evandael
    • Oct 2009
    • 2881
    what do you have against clean air, dawg?
    seriously though, if you're running OBD1 there isn't much you need to worry about. just plumb up the catch can, and if i'm not mistaken, you don't even need to worry about the throttle body heater lines, as it's an OBD2 addition.
    • FredK
      • 14764
      Honestly, I'd leave the throttle body heater circuit intact.
      It is present in the M50 and S50. You can remove the auxiliary thermostat circuit if you'd like to reduce the hose count.
      • hooken m
        • 1537
        i dont have anything against clean air. yea ill most likely do a catch can.
        i thought there really is no point in throttle body heater lines?
        • nrubenstein
          • 3148
          They are there to keep the throttle body from freezing. If you live anywhere where it gets near to freezing, you should keep them. (In other words, you're in NJ, keep them.). Otherwise, you risk having the throttle stick on you.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • 328ijunkie
            • May 2007
            • 3961
            ^This. I dont run them down here. But the northern cars ive built i always leave in place.
            Check Us out on Facebook
            Full Product Line Tuning
            • hooken m
              • 1537
              ok so i will deff keep my TB heater lines intact. what about the charcoal canister?
              • Jalves619
                • 596
                It's pretty easy to hook up. Why not keep it?
                • hooken m
                  • 1537
                  idk just one less thing to have, plus idk if i need a new one
                  • cormier
                    • 380
                    If you look into the charcoal canister stuff, it ends up being much more efficient and practical to keep it and get a new canister, it will last forever and works well.
                    No real point in deleting TB heater circuit except if you want to run a sender or something
                    If you want to run a catch can you can, but if you're looking at eliminating as much as you can why don't you just hook it up OEM stylez?
                    I don't think there's any point in not running cats in any car really, just IMO. My vibrant ones sound and look nice and eliminates the need for a resonator in my system
