M50NV Turbo Tune Options?
  • Cyrix2k
    • 593
    Originally posted by Rowleym
    Well I'm using ms2 with wasted spark. So I'm thinking, just cut the shit out of the old m20 harness and make it fit the m50 engine. Deal. This should be fun. Wait. For wasted spark, do I need cam or crank sensor?
    you need the crank sensor only.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
    • Rowleym
      • Aug 2012
      • 169
      Could I use my wasted spark setup on an m50? I'm pretty sure they use COP ignition and my megasquirt isn't able to do that.
      • Rowleym
        • Aug 2012
        • 169
        Originally posted by 328ijunkie
        Upconvert to a 413/Vanos setup. Youll be glad you did. Boost+Vanos=Better
        But wouldn't I have to ditch my megasquirt then? I already have like 500$ invested into megasquirt.
        • Cyrix2k
          • 593
          Yes, just pull the M50 coils off and run spark plug wires. I run a wasted spark setup with GM coils on my turbo M50NV. You can modify the megasquirt to run the BMW coils too, whichever you prefer. The BMW coils look cleaner but I don't think there's much performance benefit.
          1997 540i/6 - stock
          • 5Toes
            • 9836
            The nonvanos head is far better on paper for boost though?
            • Cyrix2k
              • 593
              huh? not as far as I know. Most people run them because they come stock with a more aggressive cam profile and are easier to run on a standalone. A well tuned vanos motor will spool earlier and produce more power, all else being equal.
              1997 540i/6 - stock
              • Rowleym
                • Aug 2012
                • 169
                Thanks for the info man. I'm excited for this. You have any good info on a super cheap manifold setup? Of course it has to work well. Why not just do a cast manifold? I can make custom motor mounts if that is an issue..
                • 5Toes
                  • 9836
                  Non vanos heads have 1mm thicker valve stems and less to go wrong.
                  • Cyrix2k
                    • 593
                    IMO, it's hard to beat the blunttech manifold. I paid $540 shipped for mine brand new. He even includes the gaskets and turbo hardware. You'll sacrifice fitment and quality at lower prices. When people say to do it right or do it over, that's really the truth.
                    the valve stems are about where the differences end. It's even possible to swap the vanos unit to a NV head and to delete vanos on a vanos head.
                    1997 540i/6 - stock
                    • Rowleym
                      • Aug 2012
                      • 169
                      Question. Could I possibly get the m50 harness, cut the connector off, and use my 55 pin connector that I have for my m20?
                      • Cyrix2k
                        • 593
                        Yes, you can with some wiring.
                        1997 540i/6 - stock
                        • Rowleym
                          • Aug 2012
                          • 169
                          Quick question. Is the spacing of the exhaust ports the same from the m50 to the m20?
                          • emmanuel.dlc
                            • Jun 2011
                            • 144
                            correct, that and the double spring on the NV valves. i upconverted my NV to 413 and i am using my nv head, swaped cams, front cam cover with vanos unit and a vanos valve cover and that's it.
                            • 5Toes
                              • 9836
                              I dont think vanos is really needed for boost.. I purposely bought a m50nv car
                              • Cyrix2k
                                • 593
                                it's not needed and it's easier to tune without vanos, but vanos is better for boost.
                                1997 540i/6 - stock
