My swap info....
  • Ryan Stewart
    I Love Miatas
    • 8978
    My swap info....
    There are many ways to go about the swap but this is how I did it and exactly what I used.
    Its a 1985 325e that received a 10/1995 S50 and matching tranny.
    The S50 is using its stock mounting arms but with big 6 engine mounts (E34 M5 mounts to be exact) but mounted backwards. The tranny uses all stock mounting points to the body but you can upgrade to an E30 or E36 urethane mount (or just use stock rubber). I have an E30 M3 driveshaft, unmodified. All my shifter parts are E36. I had to even change the carrier because mine was the old stamped steel model. The M3 slave cylinder needs to be changed to a regular M50 slave cylinder to match the E30 master cylinder. My old throttle cable fit.
    The engine itself is basically stock, everything that is bolted directly to the engine stayed and didnt have to move. It has the silver 413 DME which had EWS but any aftermarket chip maker makes a non-EWS chip for that DME. I mounted the E36 DME exactly like the E30 DME. I just had to use slightly larger washers. I used an E36 radiator and electric fan. You can use E30 parts in both as long as the radiator is for the 325i because of the hose routing. My overflow bottle is from a late model 325i mounted on the stock place for a 325i. I changed from the Eta bottle because of location of the coolant hoses. You can use the clutch fan if you want to, I didnt.
    Fitament. I shaved the studs off the blower fan cover and scraped off all the insulation. I mounted the wiring harness on the blower fan cover. The reader port is mounted where the old coolant bottle was. The engine power and ground are all still in the same spots. The engine pan is out of an M50 powered E34 and it also has the E34 pickup tube for the oilpump. There are redunant baffles, one on the engine and another on the pan. One has to be removed. THe oil dipstick and tube are from the E34 also. Its mounted to the support for the intake manifold. The canister for the fuel vapors is down by where the ABS would be if I had it. THe fuel filter was moved to the 325i location.
    There are two temp sensors. One is to the DME and must be a 2 prong M50 sensor. The other is to the dash and it will be a single prong E30 sensor and will be wired to the E30 wiring harness.
    My big change was braking. I used the E30 325ix booster with an E34 M5 master cylinder. Because the booster is dual chamber and the MC sticks out farther I had to use a remote brake fluid bottle. Its mounted where the relays were and used a bracket for the E36 relays.
    My exhaust consists of S52 manifolds. They are just a bit lighter than the S50 manifolds. The rest of the exhaust is hand built. I dont know about how compatible other exhausts are.
    Obviously a few things are not stock. The radiator is much thicker than the stock units so its a bit closer than your average swap would be. The cone is a must because I dont have a readily available way to mount the airbox nor do I care at the moment.
    This car has no-AC so dont ask me about how to hook it up. This is condensed. I will add the wiring as other things as I remember them and then edit this. I just thought it would make more sense than the 40 page thread.
    Im now E30less.
  • Pettas
    • Dec 2004
    • 41
    Awsome, very informative and gets to the point.
    • 1990m3
      • 1180
      nice write up, thanks.
      can you show some better pics of the brake booster/MC setup? I'm still trying to sort all that out.
      why did you go for ix booster instead of E21 320i?
      Dave
      • joshh
        • Aug 2004
        • 6195
        Thanks for all the good information!! Looks great!!
        "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
        ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
        • Ryan Stewart
          I Love Miatas
          • 8978
          I chose it because I wanted to try and use all parts off the shelf so I would be able to get them in a pinch down the road.
          The remote resevior is a stock peice also with softlines going to the MC.
          Im now E30less.
          • 325Projectz
            • Jan 2005
            • 1956
            Good stuff Ryan! Great thread idea, too.
            I'll post up the some info and pics on my swap soon.
            91 m3
            • KangamangusDriver
              • Aug 2005
              • 1870
              Ryan, Do you have any photos of how you joined the brake master and the remote fittings? What did you use/how?
              I ended up using 90 degree elbows and the stock grommits. I noticed you ran clutch line to your resevoir. What did you do to reduce the inner diameter of the master to fit the fitting of the clutch line?
              By the way, VERY NICE WORK!
              Thanks!
              • f u z z
                • 1600
                mmm. i like your radiator.
                • Ryan Stewart
                  I Love Miatas
                  • 8978
                  Thanks!
                  Its using the ends of the hard plastic remote lines hooked to soft brake lines. Im missing what you are asking on the clutch line? Its got its own little resevior with its own softlines going down.
                  Im now E30less.
                  • jrez
                    • Oct 2005
                    • 71
                    Nice work.
                    At the race track.
                    • Court M3
                      • Jan 2004
                      • 6713
                      good info for when my swap gets going. If only the car would get here
                      Continuous For Sale Thread
                      323i s50
                      • Ryan Stewart
                        I Love Miatas
                        • 8978
                        Just remember that this is for an early model car and I bought more shit than the swap *could* be done with.
                        Im now E30less.
                        • KangamangusDriver
                          • Aug 2005
                          • 1870
                          what I meant is:
                          How did you attach the lines from the remote resevoir to the brake master cylinder. (The holes that would normally be filled by the stock resevoir fittings)
                          The problem I ran into was finding a fitting to put in place of the stock resevoir fitting/hole on the master cylinder.
                          Sorry about the confusion
                          • Ryan Stewart
                            I Love Miatas
                            • 8978
                            I used the ends of the stock hard plastic remote lines. The lines from the E34 5 series.
                            Im now E30less.
