M50nv won't start (no fuel)
  • Oz10
    • Jul 2009
    • 640
    So I drove my car down to Florida from North Carolina the other night.
    It rained over night and when I went to start my car the next morning it wouldn't fire up, it would only turn over.
    I didn't hear the fuel pump priming.
    The relays were clicking randomly, even when the ignition was off and the MAF was hot.
    Long story short I found A LOT of water in my glove box. My ecu was partially in the water.
    So I drained the water and sprayed every electrical connection I could get to with electronic cleaner.
    I put the ecu in a ziplock full of rice over night to try to dry out any moisture that was left.
    So the next morning I tried the newly dried ecu out and I still wasn't getting fuel.
    The relays seemed to be back under control though. I'm showing 12v on two of the plugs for each of the relays.
    Fast forward to this afternoon. I bought a ecu and relays from the junkyard, pulled all of the old stuff off and put them in.
    ...Still nothing.
    Still no power to the fuel pump.
    I'm running out of ideas and I'm getting worried about the drive back to North Carolina this weekend.
    Can anybody think of anything I haven't? Could I have fried something else?
    I appreciate your help
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Does the fuel pump come on if you jump the relay?
    • ScHpAnKy
      • 1573
      check the main/dme/o2 relays, make sure they're in the right order... then test your CPS and make sure it alternates between open and closed as it hits the trigger on the crank pulley, then, try the fuel pump relay jump.
      91 318i | 87 535iS
      • Danny
        • 14217
        Smack the top of the fuel pump cover when you crank it.
        • eurosport22
          • 210
          jumper 30 to 87 iirc and see if the pump runs. someone correct me if im wrong on that tho.
          • NbAmTwE
            • Jul 2010
            • 148
            If your fuel pump is running did you try the e34 method of resetting EWS?
            EDIT: I should probably mention what that method is for those unfamiliar.
            disconnect negative battery lead, wait ten minutes, put key in ignition to ON position, put negative lead back on negative terminal.
            This was my issue after my e34 M50NV battery died and a day later I replaced it, it wouldn't start but would crank over. It took me forever to find the info online about this but as it turned out the ECUs ignition security wouldn't actually send fuel (iirc) through injectors until it was reset this way.
            UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
            stripped out e30 rally project - in progress
            M50NV -> M50TU E34 swap underway
            • 328ijunkie
              • May 2007
              • 3961
              eeek! Sorry to hear austin
              Jump the pump and see if it runs. I hope no wiring got fried. Youve already had some fun there :(!
              Check Us out on Facebook
              Full Product Line Tuning
