So i am buying my self a 1992 e36 325is parts car very soon. I have a 1987 325is i am wanting to swap the M50B25 into. I have done alot of research... But it seems as if they contradict each other. SO i have a few main question about the swap/ motor and i appreciate all the help! thanks.
1. Am i able to use the Getrag 260 i currently have in my car without modification? ( I am really hoping this is the case)
2. Am i able to use my motor and tranny mounts i have now?
3. I am aware that the e34 oil pan is needed, but do i need the sump and tube as well?
4. I know the brake booster needs swapping, (or modding heavily) and ive seen people use e21 brake boosters, but are those boosters crap? is there another booster i could use?
5. Do wiring adapters such as this, http://www.harrisonmotorsports.com/w...-e30-swap.html make it to where all i do is plug it up and the wiring is done? ( i am also aware i will need the e36 ecu and engine wiring harness)
Now onto some engine questions.
1. Will the e36 flywheel bolt right up? and can i use my 325is clutch or will i need to get a m3 clutch or a Performance one?
2. Will M3 headers work on my car?
3. I am looking to do a full tune up to the motor before it goes in (obviously) and I were to take the head off, and get a nice polish and port, would it be a good thing to do? (im also going to get APR head studs and a "performance" head gasket) because after the swap i am wanting to save for boost.
Thanks alot everyone, all of this will really help me out. As i said these are just questions I've had after doing research. Im sure The people of R3vl will be able to shine some light on these areas.:D
