M50TU S50 cams
    M50TU S50 cams
    What other mods/hardware should be used to get the most from using S50 cams in a M50TU?
    Injectors? ebay S50 chip or W.A.R. chip? bigger MAF?
    24# injectors, 3.5" maf, Turner chip is what i have found to work great
      3.5" maf is not an upgrade. The throttle body is a restriction even with the stock 3" maf.
      OP just get a chip for the s50 cams from TRM or somewhere like that. I'd avoid ebay as you have no idea what you are getting. If you want to upgrade injectors, I'd do 21.5# maximum. 24# would be way overkill for an m50.
