Positive battery terminal block in engine bay.
  • equate975
    • Jun 2004
    • 3382
    What did you use? How did you guys mount it? I made my own by cutting up the old e30 block.
    Post pics, I wanna clean mine up it looks like crap!
    Rollin' with a Geistkuchen
  • NickP
    • 257
    I just put a battery terminal replacement on the e36 line and mounted it like stock. You can also reuse the standard e30 cable.
    • 02stu
      • Jan 2005
      • 872
      The wires that need to be connected to it are on the wrong side of the engine bay. Did you just extend them?
      • equate975
        • Jun 2004
        • 3382
        I can think of about 15 ways to make it work, I was just wondering what you guys' stuff looked like. Mine wouldnt mount in the stock location because I think the e30 m3 mounting point is different.
        • NickP
          • 257
          The power distribution block is on the passenger side firewall - I didn't have to lengthen anything. I hooked up the ground to the passenger side strut tower - again to the stock ground point.
