e34 DME/harness mounting pictures
    Curious to see how you all have mounted your e34 DMEs into the factory location on the e30. Let me see so me pictures so I can see how I'll have to mount mine. Thanks!
    Chris
    im pretty sure u just flip it around backwards of stock. sorry no pics i had a e36 harness
      I've been reading that, too. Just wanted to see some pictures of peoples handy work.
      Chris
        Anyone?
          I did that, too. flipped the dme around so the connector is facing forward. i'm gonna need to get it there in the near future so when i do i'll snap a few pics for you.
            you need the e30 318 ecu brackets.. i think the #'s are
            12141727498
            12141727499
              I appreciate it.
              Chris
                12141727498
                12141727499
                Got the bracket already, just haven't hooked up the wiring harness yet. Thanks though.
                Chris
                  I used a DME from an E34, it just seemed obvious how it mounts with the 318 brackets.
                  Originally posted by mbonanni
                  I am a pursit now.
                    his problem is not the DME. it's the wiring harness. he got it out of an e34 (like i did) and it's shorter than the e36 one therefore it doesn't reach around the dme above the glove box. An easy fix is to mount the dme with the connector facing forward but then it doesn't play nice with the bracket...
                      This. So what I'm gathering is that I mount the DME "backwards" and just get it to work in the 318 bracket. I'd still like some pictures of others hadny work, but I'm guessing it'll be self explanatory when I get it all hooked up.
                      Chris
                        In for the info, i also have an e34 harness
                          For those of you that are using the e34 harness, did you have to extend the 3 ground wires that go to the 3 relays? I'm having trouble getting enough harness into the interior to be able to run the DME backwards in the 318 holder.
                          Chris
                            I'm still gathering the last pieces and will start my swap at the end of February
                              Chris
                              i did extend 1 ground wire for sure but i don't remember which one it was.
                              I didn't forget about the pictures i promised you. I'm just really short on free time lately. :(
