S50 running issues
  • Danny
    • 14216
    S50 running issues
    Alright so, I have an S50B30 in my car, OBD1 of course. I'm having some issues with it. It started with an intermittent dying problem that would occur from time to time. This problem was solved by whacking the top of the fuel pump until the car kicked back to life. Eventually this Fonz style trick stopped working.
    I then replaced the fuel pump and the three relays on the engine harness, the issue was fixed for about a week. Then I smoke tested the intake and found I had a huge vacuum leak where I repaired the brake booster nipple. I then replaced the intake manifold and every single vacuum fitting and hose. I also replaced the CPS. At the same time I installed my OBD2 pink top 21.5 lb rebuilt injectors. This was done after numerous techs told me it was fine and the car would still run fine. After that the issue persisted. I can start it and drive it but the car would die when letting the clutch out unless I slipped it quite a bit. Once I got out of the lower RPMs (<2500) the car ran fine, had good power, etc. If the car died I could crank it and it would come back to life but only after around 20 seconds of cranking. It would then idle very low for a minute or so until it seemingly "cleared itself up" and the idle picked up.
    Then I replaced the spark plugs, the plugs that I pulled out of the car were pitch black and a tad bit oily on the threads, nothing on the electrode however. With the replaced spark plugs it ran a bit better but still had the same issue when I touched the throttle. I have uploaded a few videos for you to look at.
    Ignore the high idle, I adjusted the throttle cable to have a high idle. Ignore the brake booster hose, that is temporary to ensure there is no vacuum leaks (or at least obvious ones)
    My theory is the O2 sensor may be old and too lazy to properly adjust the fuel mixture for the larger injectors without a tune. I am going to order the proper tune from Turner tomorrow. My other idea is that my shitty aftermarket magnaflow cat that is rattling around may have finally clogged my exhaust. Lastly, could this be indicative of a headgasket leak? The only thing out of the exhaust is a fuel smell and steam due to the cold weather.
    Cliff notes version: replaced all vacuum related items and intake due to massive vacuum leak, replaced fuel injectors with OBD2 injectors, see above videos.
    Any help is appreciated, thanks.
  • e30user
    • 36
    I've had odd vacuum like issues be caused by a bad mass airflow sensor. Although to be honest, nothing as severe as your symptoms. I'd still say it's something worth looking into, especially if you can borrow one from a friend just for testing. I think you can also try disconnecting it to see if things change at all. Also, is your check engine light hooked up, and giving any codes?
    • Danny
      • 14216
      If I unplug the maf, the car dies. I have a check engine light but only at high rpms when the engine is cold. It throws maf code at those upper rpms.
      Also, when the pulled the plugs they were pitch black. I don't remember if I mentioned that or not.
      • FredK
        • 14755
        It might be a flaky fuel pump connector. I had to do the "Fonz" for a while. It turned out the fuel pump connector on the pump got damaged. The ground side started to melt and the pin got half-covered in melted plastic. The car would never die during times of higher engine load, but would die at idle.
        So, I removed the melted plastic so that the pin was clean and fully unshrouded, and spliced on a new fuel pump connector.
        I would open the fuel pump access hatch, and turn the car on and try wiggling the connector. If the pump buzzes on and off, you have intermittent electrical contact.
        • Danny
          • 14216
          Thanks for the insight Fred. I solved the intermittent no start by replacing the brand new fuel pump relay with a used one, the brand new one was no good.
          Do you think a bad fuel pump connector would cause these issues?
          • P.Kelly
            • Aug 2011
            • 367
            I had an issue on my M20 that was similar. Turned out one of the maf connectors wasn't seated all the way. Engine would get too much fuel or not enough fuel and sputter. Sounds like you've you've already checked your MAF though.
            The Definitive 1991 M-Technic Thread - a work in progress
            • Danny
              • 14216
              Thanks for the suggestion Pete. I have only checked the MAF by unplugging it and seeing what the car did. A co-worker is going to lend me a spare MAF to check again.
              • FredK
                • 14755
                A bad fuel pump connector could cause an issue with these symptoms. I'd wiggle the connector around to see if the pitch of the pump changes at all.
                • Danny
                  • 14216
                  Okay, I will look into that.
                  • e30user
                    • 36
                    Originally posted by Danny
                    If I unplug the maf, the car dies. .
                    Did you unlpug the MAF while the car was running? I think it could be normal for it to stall if unplugged while already running. My understanding is that the car should run in some sort of limp/fail mode if the car is started with a dead/unplugged maf. I could be wrong about all of this, but if your car can't ever run without maf, it might be a clue to narrow things down to something beyond my knowledge.
                    Something else that came to mind is the throttle position sensor. I remember a friend who would have unpredictable throttle response due to this, especially when stabbing the pedal. However, that was on an M20 and I don't know if it's directly relevant to S50s as well.
                    As for a head gasket leak, I don't think it would cause those symptoms. You'd notice other things before performance issues that severe, like some real obvious oil and coolant mixing and a much cloudier exhaust than what you're seeing. I don't have any guesses for the clogged cat, but at least that's something you can disconnect and test without spending money if you do it yourself. Don't failed cats result in a sulfur/rotten egg like smell? Maybe that's not always the case.
                    • Danny
                      • 14216
                      Correct, I only unplugged it once it was running. I'll give it a shot before I start the car as well.
                      I'll have to probe around with a multi meter, that could be a possibility.
                      I agree with the your thoughts on the head gasket. As for the cat, I'm not sure.
                      • e30rapidic
                        • 2167
                        fuel pressure regulator?!?!
                        '87 325ic, powered by S50.
                        • Danny
                          • 14216
                          Replaced that a while ago with a new one. Could be an issue though I suppose.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Never had a FPR go bad... like ever...
                            Your flooding out the motor big time if you dont have a chip for the 21.5's.
                            17's to 21's is a big jump and the OBD1 electronics will never be able to compensate for that.
                            And by the vid. You have a Vac leak. The RPMs drop when you open the throttle not rise immediately.
                            Check Us out on Facebook
                            Full Product Line Tuning
                            • Danny
                              • 14216
                              I have just replaced every single vacuum component with brand new parts. I'm not sure how there could be a vacuum leak, unless an M50 nonvanos intake manifold is different from a vanos m50 intake manifold.
