Need a quick response!
  • nl328i
    • 556
    Hey guys, sorry for the demanding title thread (asks for forgiveness)
    I just got a text from my mechanic who is in the middle of the swap and he wants me to confirm what clutch setup I am using before he gets at it, so he is waiting on me...
    I am swapping in an 1995 s50 and transmission into a former auto e30
    I was assuming i could use the clutch master cylinder and slave cylinder from the m3? I bought an e30 manual pedal box as well.
    ANy advice?help?
    1976 2002, 1987 325is, s50 1991 touring, 1996 328i vert
  • nl328i
    • 556
    I know the rule is to use the slave from the swapped transmission, but what about the master? is the e36 m3 master ok? will it all connect up properly with the e30 stuff?
    • Danny
      • 14216
      No use the e30 clutch master. Match the clutch kit to the flywheel being used.
      • nl328i
        • 556
        I don't think I have an e30 clutch master, as the e30 was an auto.
        I was planning on using the flywheel from the e36 transmission.
        • Danny
          • 14216
          That's fine. Use an e36 m3 clutch kit then. You'll have to order an e30 clutch master cylinder. I can help you with that. Shoot me an email, my address is listed in my signature.
          • nl328i
            • 556
            So the e36 CMC won't work?
            • Danny
              • 14216
              I am 95% positive that is correct.
              • JFarhanbod
                • 2151
                from what ive been told, the master has to be for an e30. i have a couple extras here if you want to buy a used one.
                • 328ijunkie
                  • May 2007
                  • 3961
                  Replied to your email andrew.
                  E36 clutch master doesnt really bolt in to the E30 pedal box.
                  Check Us out on Facebook
                  Full Product Line Tuning
                  • Roysneon
                    • 4505
                    I'm in Halifax and can send one your way first of the week, possibly Friday if you really want a used one. Just pay for shipping and my time to pull it from my parts car.
                    Originally posted by mbonanni
                    I am a pursit now.
                    • nl328i
                      • 556
                      Thanks for all the info guys, r3vers are the best.
                      Roy, it looks like I am buying a new unit from Danny but if that falls through for whatever reason I will let you ow considering how close you are. Much appreciated man.
