check out my build thread.. I had to stretch my DME harness to get the bracket to mount up inside the glovebox. Would be much better if the dme was upside down
Is my DME mounted correctly??
I think you need to go one more notch further back like below, although it looks like you have an AC line behind, not sure if that will cause clearance issues.
Picture taken from cjdontthink's thread here: http://www.r3vlimited.com/board/showthread.php?t=266738
E34 harness FTL
If you open up the wire 'box' in the center you can cut some zip ties and buy yourself another half inch.
Check Us out on Facebook
Full Product Line Tuning
Dont use it :P. I put the C101 under the 318 covers in its factory mount:
