Those of you running OBD2: IAT Sensor
  • 328ijunkie
    • May 2007
    • 3961
    You should be running the OBD2 IAT for this reason:
    :P!
    Check Us out on Facebook
    Full Product Line Tuning
  • Boise
    • 212
    So I saw the first sensor temp, the OBD2, and thought holy crap! 94 degrees! Thats hot as hell for January for temp with a hood open...then realized you live in Georgia. Its 13 right now at my house.
    Big difference between the two sensors. So if I understand this correctly, the OBD1 sensor would read hotter, the DME would think their is less air (hot air being less dense), adjust accordingly, causing the engine to lean out?
    • 328ijunkie
      • May 2007
      • 3961
      ^Correct for the most part. Not really lean out but restrict ing. timing slightly.
