Does my car have EWS or not?
  • Tico Frank
    • Feb 2011
    • 351
    I have not been able to get pulse to my injectors and am wondering if the dme or harness has some ews or other security system in it. I bought the engine already pulled and it is from a 1995 325is. I did not get the computer from the same car but it is a 413 red label dme. If I do have ews how can I disable it without buying a chip?
  • bimmer630
    • 1230
    If you have EWS wont there be some extra connections on the harness for the coil around the key and the EWS control module, no?
    does your crank sensor work?
    • Tico Frank
      • Feb 2011
      • 351
      I tested the crank sensor and the wire for continuity from the crank sensor wire to the dme side.
