Clutch Masters FX100 S52 G260
I was looking at this clutch set up as well. While I was searching around it seems like the BMW guys haven't had much luck with Clutchmasters. I've also found the following on other set ups:
Clutchnet: If you get one that works you're set, if not, it probably wont disengage and then good luck getting a replacement/fix in a timely manner.
Southbend: Awesome setups and good success for the guys on Bimmerfourms FI, but nothing for the M20 spec that I could find.
UCC Performance organic: Awesome setup, but a bit pricey.
This is just what I've seen in my research so it may not be the case.
And i'll throw this in there before LJ851 chimes in lol:
Originally posted by LJ851 View PostYou could also get it rebuilt and beefed up (more straps) and more grip if you want. Great work at a good price here:
http://www.clutchspecialty.com/
i got the fx100 with my s52 lightened stock flywheel with g260
its awesome nice and stiff. not too stiff not to soft and wimpy, bites nicely
10k strong with countless auto x and track days and drift events and i beat it around town if i feel like it
just use oem throwout bearing always...
clutch masters has like a plastic throwout-ewYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Trust me it stock :yawn:
I am using the clutchmasters fx100 with the g260, m20 single mass flywheel, and a mostly stock s52.
My reasoning was it'd be stronger than a stock m20 clutch kit, and it is. However, it's a little harsh for the daily driving I do. As in, your either spinning tires, or stalling it, but not that extreme. While it definitely holds the power, and has a nice bite, if I could go back, I would have just ran an s52 flywheel and stock s52 clutch kit.
