OBD1 S52, no fuel, no spark
  • TheRealE30kidd
    • Jul 2010
    • 496
    it was checked out when we did the test.
    The Current Army
    -(UnderConstruction) 1991 330iS 24v S52 build thread
    -1992 325iC
    -1987 E30 Truck
    -1991 332iS (BecauseRacecar)
    -1988 Dinan M3
    -1988 325iX Tribute car
    -1989 320i Touring (S52/6spd)
    • TheRealE30kidd
      • Jul 2010
      • 496
      Ok, narrowed it down to a ground issue somewhere between the DME and the main relay. When we manually ground the main relay, fuel comes out. Checked all the ground wires and they are all good.
      Every ground wire from the DME connector to the relays are good. No ground signal coming out of the DME though.
      The Current Army
      -1992 325iC
      -1987 E30 Truck
      -1988 Dinan M3
      • Roland H
        • 4480
        Ground strap on the engine? What DME do you have? Cut that EWS wire anyway.
        • e30austin
          • 15382
          Yup, ground strap is attached from pass side engine arm to frame. 413 red label dme. I was thinking of cutting it but don't think that's going to cause a ground issue (I could be wrong though.)
          • 328ijunkie
            • May 2007
            • 3961
            The EWS wire doesnt go anywhere so no use in cutting it. The ECU controls the fuel pump. If its not firing the FP then look at crank signal or chip or ECU itself. The only thing the OBD1 electronics *need* to fire the motor are the ECU/Chip to be working and the crank sensor. You could have everything else broken and it would still fire. (sans coils/plugs and injectors obviously.)
            Check Us out on Facebook
            Full Product Line Tuning
            • TheRealE30kidd
              • Jul 2010
              • 496
              We tried austin's ECU out of his car that is a good one and that didnt change anything.
              The Current Army
              -1992 325iC
              -1987 E30 Truck
              -1988 Dinan M3
              • e30austin
                • 15382
                Crank sensor is also brand new and ohms out within spec (565 ohms.)
                • TheRealE30kidd
                  • Jul 2010
                  • 496
                  Ideas?! Still stuck. Only thoughts bad hardness??!
                  The Current Army
                  -1992 325iC
                  -1987 E30 Truck
                  -1988 Dinan M3
                  • 328ijunkie
                    • May 2007
                    • 3961
                    Triple check your power/ground connections for the harness.
                    • mtlbloodshot
                      • Jul 2011
                      • 761
                      You made sure the ground on the fuel injector rail is good? Make sure that resistance is not screwing you over.
                      MY BUILD THREAD
                      http://www.r3vlimited.com/board/showthread.php?t=235231
                      INSTAGRAM : @luchcolaneri
                      • TheRealE30kidd
                        • Jul 2010
                        • 496
                        Picked up an OBD1 harness from pick n pull along with another red label 413 just because. From a 1994 325is manual. It is still doing the EXACT same thing. No power to fuel pump relay or main relay.
                        I'm done at this point.
                        The Current Army
                        -1992 325iC
                        -1987 E30 Truck
                        -1988 Dinan M3
                        • 328ijunkie
                          • May 2007
                          • 3961
                          Take a picture of your power/grnd connections at the firewall.
                          A pic of your C101 wiring would help too.
                          • e30austin
                            • 15382
                            Will do in the am (well, when I back to the car.)
                            • e30austin
                              • 15382
                              Here's the power block. Harness adapter is brand new from AKG, so I didn't get any pics of that.
                              • 328ijunkie
                                • May 2007
                                • 3961
                                brand new doesnt necessarily mean correct. People make mistakes
