I got my OBD2 e36 harness all wired up today for the most part, and I had a few questions.
1) I moved the VSS signal from x6031 pin 3 to pin 14 in the c101. Do I need to also move pin 1 in the x6031 for the CEL? I have read conflicting reports on this. If I need to move it, what pin on the c101 does it go to?
2) I plan to eventually hook up my AC system. Is there any wiring that required to run it that I should do now? I see pin 4 on the x20 is for the AC compressor control. Do I need to connect that to the car body electrical at all, or is the AC run through the car body harness and bypasses the engine harness?
3) The car is a late model, and c101 pin 20 on the body is yellow/red. I need to connect that to pin 6 on the c101, then connect both of those to pin 22 on the x20?
Thanks!
Thanks!
