s50: Hesitation/stumble on initial accel
  • aaron.j
    • Jan 2006
    • 529
    95 s50 in e21. S50 is completely stock except for an m20 single mass flywheel. Engine hesitates when stabbing throttle at idle or trying to drive. It is only off closed throttle. if I hold the rpm above 1500 or so and stab it it does not do it. Engine idles smooth around 750 rpm. Smoke tested no vacuum leaks. Fuel pressure at 43 psi. Any thoughts?
  • 328ijunkie
    • May 2007
    • 3961
    unplug MAF. Try again
    Check Us out on Facebook
    Full Product Line Tuning
    • aaron.j
      • Jan 2006
      • 529
      forgot to mention that was the first thing I tried no luck
      • aaron.j
        • Jan 2006
        • 529
        Rubber hose inside tank from pump to sender failed. Runs like a champ now.
        • bimmer630
          • 1230
          Pics of e21 swap?
          • aaron.j
            • Jan 2006
            • 529
            Post your build threads here! Keep us updated on what you're doing in your garage.
            have some pics in the engine bay threead too
