S50 + UUC stage2 + M5 clutch + getrag 260 = possible?
  • MatRacer
    • 562
    S50 + UUC stage2 + M5 clutch + zf from a M3 95
    This setup was mounted on the swaped car I bough. The tranny seem to be shot and I would rather go with the getrag 260 I also have. Will the UUC stage2 + M5 clutch fit on the S50 with the getrag 260?
    Which slave cylinder do I have to run?
    thanks!
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • 328ijunkie
    • May 2007
    • 3961
    Slave matches trans. Use 260 slave and you should be fine. I just went the other way with my 260. Had M20 single mass setup and am now running a M52 Clutch/FW; reused the 260 slave.
    Check Us out on Facebook
    Full Product Line Tuning
