M52 misfire
  • isra
    • 177
    M52 misfire
    Ok, so my e30 has been sitting for about 3 weeks, an now that i want to drive it it has a misfire i think.. I noticed this when i was getting on the freeway today
    Its around the 2.5k-3k rpm range. I loose power an get a deep exhaust sound, after 3k rpm car would go back to normal. Then i decided to floor it after the misfire an car would bounce off 5k rpm and will not go over that..
    I check the coils by disconecting one by one an they are good
    I got new plugs since i had 2 years with them..
    An still i get the misfires now im thinking cam sensor, but i would like more ideas from my r3v fam... Thanks!
  • Mr.SWISS
    • Nov 2005
    • 1251
    My car did this when the compression in #2 was low in the S52. lopy idle, throttle cooks up, not steady, hits 5K and falls on its face when it had crazy pull before...
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
    • isra
      • 177
      That sounds bad.... I hope thats not my case
      • isra
        • 177
        Anybody....
        • !kid
          • 1362
          bad throttle position sensor maybe?
          :borg:
          • Cynical 1
            • Nov 2012
            • 129
            do a compression test. google how to do it properly.
            other option is fuel injectors, or a bad sensor - cam or tps.
            1988 325 "super ETA" - Hilde - M52B28 swapped...
            1969 2002 - Griselda - 20VT AWP swap and full resto in progress...
            project blog - http://www.cynicalmotorsport.blogspot.com/
            • isra
              • 177
              Okay so this morning i got up at 4am to start work at 5am an i took my e30 i was driving down the freeway an the car was still cold.. An it didnt have any issues, i got on it an took it up to 115mph... Pulled strong all the way no problems at all.. I made a stop on a 76 gas station to get some coffe got back on the car an then same problem started again will not go over 5k an it would misfire at 2500-3000k rpm... So this issue will only happen when the temp is in the 1/2 way mark/operating temp
              • Plynch2
                • Apr 2012
                • 56
                It's probably you crank position sensor. my car ran great cold once it got warm it wouldn't r3v past 5000rpm. Replaced it today now it runs perfect.
                • isra
                  • 177
                  Im going to start with a compression test Just to get that out the way. About the sensor whats a good way to test them...? I just dont want to waste money in sensor i dont need.
                  • Plynch2
                    • Apr 2012
                    • 56
                    Look up the ohm readings on google test it cold and then warm. Mine was in spec cold but after the car got warm it was out of spec.
