S52 cut out @ 6k
  • Jparkr
    HR Admin
    • Jan 2006
    • 3494
    S52 cut out @ 6k
    Ok, so this is currently in my E36 318ti. I am getting it running perfect in that chassis before I swap it into an E30. I am almost there except this one issue.
    99% of the time when fully accelerating, when it hits 6k it just cuts out and kicks back on. The cut out only lasts about a second. I am still running on a 3.0l 413 Red label DME.
    Anyone experienced anything similar? This is the only problem I am having.
    1987 PRO-3 car /1990 325is (2.7i Concours)
  • 328ijunkie
    • May 2007
    • 3961
    Knock or crank sensors.
    Check Us out on Facebook
    Full Product Line Tuning
    • Jparkr
      HR Admin
      • Jan 2006
      • 3494
      Knock sensors are cracked. Thanks man, I will start there.
