Hi guys, sort of an add question here.
Trying to clue up the s50 swap into the touring. The touring had been an automatic so I am also swapping in the m3 transmission (1995).
The only issue is that it appears that the shifter arm bearing (#4 in this diagram:
http://www.realoem.com/bmw/showparts...13&hg=25&fg=05) is missing from the shifter. The previous owner told me he had swapped in a z3 ssk so to speak, so I don't know if that will impact on anything. Essentially I need to know if I buy the e36 m3 shifter carrier bearing or if I buy a e30 one. I'm assuming I get a new e36 one as I haven't read anywhere that this won't work in an e30. Any advice or input is appreciated.
