Yet another story of an m50 swap that will crank but not start and I'm looking to all of you for some help.
Just finished getting everything hooked up on my m50nv/g260 swap and it will crank but not start. I'm not getting spark or fuel. If I jumper pin 30 and pin 87 on the fuel pump relay base the fuel pump runs, filling the injector rail. I've tried various other relays and none work, so it doesn't appear to be a relay issue that is causing my fuel pump to not activate when starting.
I pulled a spark plug and tested it out of the head and I wasn't getting spark. I checked the resistance on the coils and they are within the proper ohm range. I've got all of my grounds connected and have triple checked my x20-c101 pinout. I replaced my CPS with one that tested in the proper ohm range.
Anything else I should be checking for or looking at solve this issue? Is there something I should be hooking up from the DME, being that it came out of an auto car? Thanks for your help. I'd really like to get this thing running before I head to Afghanistan for 6 months, four days from now.
Chris
Chris
