Solid UHMV 24v swap mounts
  • e30time
    • 108
    I found these listed on the auction site, and was curious if anyone has gevin them a try? Same seller also sells some other pertnent parts, including a power steering delete block that looks interesting.
  • DREWHALL
    • Feb 2006
    • 1207
    Made by a user on here/the shop he is associated with. Good stuff from what I've heard. I keep wanting to get them but already have mounts of the same material.
    • e30time
      • 108
      Great, thank you.
      • shiboujin
        • Feb 2006
        • 2791
        IMO they are piles of crap. They don't incorporate for the fact that the E30 subframe and E36 motor mounts are at different angles. It makes for bad fitment and it requires the material to "deform" to fit "properly"
        • Roysneon
          • 4505
          Those mounts will not deform. I have them on my 14v and despite being a bit rough, they are great.
          Originally posted by mbonanni
          I am a pursit now.
          • shiboujin
            • Feb 2006
            • 2791
            oh they'll deform. lol. But that's also why I put it in quotes.
            • Jalves619
              • 596
              Have you had the Condor Mounts in hand? From the picture above it looks like they may have accounted for the angle difference.
              • shiboujin
                • Feb 2006
                • 2791
                Yes. They have the offset threads like the revshit ones. Flat. no taper.
                • ZekeTheSneak
                  • 1562
                  I'm disappointed in my revshift mounts with no angle. I recommend using the Amy ones it will make lining up the motor much easier. I like everything that condor has made thus far.
                  • e30time
                    • 108
                    What are the "Amy" ones? AKG unavailable right now...
                    • shiboujin
                      • Feb 2006
                      • 2791
                      I'd wait for the AKG ones. They fit the best and actually made it so I could use an M20 clutch fan. JUST barely but I'm ok with it.
                      • Jalves619
                        • 596
                        That's too bad. I'm looking for a non-e28 solution. I will probably snag a set of the AKG ones once I can afford them and they are back in stock.
                        • giantkeeper
                          • Aug 2009
                          • 1416
                          AKG mounts, are the cats meow!
                          Always Always go for the reach around if there is an option
                          • AnimalE30
                            • Aug 2009
                            • 266
                            Damnit.
                            • ZekeTheSneak
                              • 1562
                              meant akg, Damn auto correct.
