Wish she'd warm up faster!
  • cormier
    • 380
    If your tstat is good, I would make sure you're bled properly. Feel the rad hoses to see if one is lagging in temperature and holding air.
    Did you use your m20 temp sender? Maybe your gauge is reading low. Try using a digital thermometer gun and compare if you have one.
    • 325e10
      • 161
      As a side Note, I drilled a hole in the 12 o'clock position on my thermostat to aid with bleeding. Also am not running the bypass valve.
      • AndrewBird
        The Mad Scientist
        • 11897
        An air pocket would cause it to run warmer, not colder. Have you checked to be sure the temp gauge is reading accurately?
        • 328ijunkie
          • May 2007
          • 3961
          Hcore hoses routed wrong is my bet. I get warm air in 4-5 min and burning hot air in 10 min. on my swap car with an 80C thermo.
          Check Us out on Facebook
          Full Product Line Tuning
