Driveshaft Question
  • e30time
    • 108
    Driveshaft Question
    It makes sense that sense I'm using a M Roadster Diff with the ZF trans that the driveshaft from an M3 would work... anybody know for sure?
  • mtlbloodshot
    • Jul 2011
    • 761
    ZF trans have a 96 mm output flange with a 12 mm bolt hole. So does the M3 drive shaft. You'll be good mating it with the M roadster diff..
    On my M52 swap, I have a ZF310 with a E36 328 driveshaft to a Z3M Diff. Fits perfect.
    MY BUILD THREAD
    http://www.r3vlimited.com/board/showthread.php?t=235231
    INSTAGRAM : @luchcolaneri
    • e30time
      • 108
      That's good to know, thank you!!
