Coolant reservoir
  • JayGotti
    • Jul 2012
    • 200
    Coolant reservoir
    So I swapped out my m20 for an m50 and it's an 87 so you have the bottle on the passenger side. But I bought the one on the driver side but I don't know what clips to buy. Can you guys give me the part numbers for it? And the power steering fluid bottle is zip tied to my air filter and it was fine until one day the power steering no longer started to work, the fluid looks fine in the bottle. What could the problem be? I am considering buying the ps delete but am also going boost. What do you guys think?
  • JayGotti
    • Jul 2012
    • 200
    filled the ps it works now just has a really annoying skreitch while turning. any one know the part number for the clip?
    • !kid
      • 1362
      have you checked realoem.com yet?
      :borg:
      • JayGotti
        • Jul 2012
        • 200
        Yes but I am confused on which is the correct one
        • M3PO
          • May 2012
          • 537
          The bottle on the driver's side fender has two pieces that need to be welded. One is a threaded stud welded to the fender and the other is a "strap". I doubt that you will be able to buy those separate. I took them off a junkyard car.
          • frankie591
            • Feb 2012
            • 545
            I took measurements from a late model car and just bent up the strap piece and welded a stud on. Worked great.
