Dipstick tube bracket for using a 525 oil pan?
  • hugh jass
    • 2220
    Ok, here is the situation.
    I need to order the proper later E34 525 dipstick tube to go with the 525 oil pan i have on my s52 motor. Patrick at BMA can't find a part number for the bracket that holds the dipstick tube. RealOEM says the bracket pictured was used up until 7/91, and they don't have a part number listed for anything later. Does the later 525 tube have a bracket built in? Anyone have access to a real ETK? Thanks.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
  • aeryk7
    • Oct 2005
    • 616
    www.realoem.com
    253rwhp
    My Vids(OLD)
    http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
    http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
    • hugh jass
      • 2220
      If you read my post, you'll see that I state that realoem doesn't answer my question.
      • Addissimo
        • Mar 2004
        • 1820
        it is welded to the tube.
        dont worry about it.
        -Addis
        Doing something M50 related? -> http://www.addissimo.com
        On Myspace? ->http://groups.myspace.com/r3vlimited
        BF2142 SN = BillyGoose
        • 325Projectz
          • Jan 2005
          • 1956
          I just made my own, easy to do.
          91 m3
          • equate975
            • Jun 2004
            • 3382
            I never bolted mine down I just stuck the fucker in and said good enough. lol
            Rollin' with a Geistkuchen
            • 1990m3
              • 1180
              how hard is it to slip the dipstick tube in the oil pan hole? I tried today while I was working on some stuff, didn't seem like it wanted to go. I figured I'd take a closer look at it later, the motor isn't even in the car yet.
              • 325Projectz
                • Jan 2005
                • 1956
                Sure you have the right dip stick? It should just slide in.
                91 m3
                • Jason89i
                  • Sep 2004
                  • 875
                  after replacing my o-ring, it did take considerable force to get the o-ring to pop into the groove. cheers, jason
