i took off the manifold to change the temp sensor to the m20 one and put everything back and the car started acting like this http://www.youtube.com/watch?v=jbRRmDzNflM i dont understand whats the problem. also the temp guage still doesnt work, i cleaned the terminals in the cluster and tightened the ground terminals, ill try an new sensor and see if tht works.
misfire
And did you plug all the injectors back in correctly ? I bent a pin on one of my
Injector harness plugs and that was curing a misfire forever. .1985 325e M50TU(Sold)
1991 318is Slicktop (Sold)
1990 325is Brilliantrot S50/5 Lug Swapped.
1992 525i Manual shitbox Winter Beater -
[QUOTE=TimKninja;3655058]Did you change the right temp sensor ?
Injector harness plugs and that was curing a misfire forever. .[/QUOTE
i took it off with the fuel rail all together and yes i believe its the right sensorComment
