after 24v swap my windows no longer function
  • hooken m
    • 1537
    hey guys after my swap my windows no longer work. at first i didnt care cause it was like 30 degrees everyday but now that the weather is warming up i'd really like to be able to use my windows. i heard its something with a resistor or something? any help would be appreciated.
    Originally posted by evandael
    a car is a car. call it a dildo, i'd still drive the hell out of it.
  • agile30
    • 832
    Did you accidentally forget to plug in the window circut to the right of the shifter? That little button that can piss people off causing them to go insane.
    Originally posted by Good & Tight
    It takes real man to mount a big woman, all you haters are just scared boys.
    • NickL
      • 562
      How is your starter wired?
      1987 325is - S52
      • hooken m
        • 1537
        i have a vert so im not sure if i have one of those buttons. i just looked. a pic would help
        i dont remember how i wired the starter, but i didnt know that the starter wires had to do anything with the window
        • StereoInstaller1
          GAS
          • 22679
          Welcome to the wacky world of BMW electricals.
          Do a bit of research on "unloader relays" and go see if your HVAC fan works...it won't.
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
          • hooken m
            • 1537
            i mean ive been driving the car for about 2 months now. my heat worked fine up to 2-3 weeks ago. i took an hour long trip worked fine. on the way back the heat stopped working randomly.
            • S62
              • Nov 2011
              • 262
              These might help you.
              My switch was bypassed by jumping the wires therefore eliminating the switch.
              • Sicksappeal
                • Mar 2012
                • 3
                Somebody please help this guy find a solution, this car sounds way too dope to have to listen to through panes of glass :thumbup::D
                Sent from my DROID4 using Tapatalk 2
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  There is a small wire that plugs into the 10mm stud / nut on the back of the alternator that goes to the back of the starter solenoid. If that is disconnected or loose then your power windows will not function.
                  • StereoInstaller1
                    GAS
                    • 22679
                    Yes, the wire is green/black and should be grounded when the car is not cranking.
                    Meaning when cranking it is either open or 12V...but no matter. Most everyone simply grounds it, heaven forbid you use your HVAC fan or windows while starting your car...
                    Closing SOON!
