The Poor Man's M50 3.0l Stroker Dyno Numbers are in.
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Still a nice budget idea. You can pick up the head/block for $500 all day long, and the internals are probably not far off of that either. Add in some machine work, preventative maintenance and new bearings, and you're probably around $2500 which isn't bad. I'm not sure what s50/s52s are going for these days though.
    • BMWerke
      • 893
      Im doing the same thing, just waiting for the g260 swap brace to get here. Everything is new and im def under $2k all together.
      '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
      '86 325e- Donor car for swap/parts car
      '00 323i- BBS 197s Totalted
      '89 740 turbo Volvo- Donated
      • Paradox
        • Jul 2010
        • 337
        Why did you use a non vanos head with a vanos block and then convert it to run vanos?
        Parts availability?
        • RobertK
          Kicked cancer's ASS.
          • Jun 2005
          • 5864
          Parts availability?
          Pretty much.. and double valve springs are nice but we built it on his budget and parts he randomly pulled.
          • Paradox
            • Jul 2010
            • 337
            Ok.
            I'm thinking of converting to Vanos as well. Did you notice any differences with toothed crank pulley? Can I use a non vanos pulley on vanos block?
            • RobertK
              • Jun 2005
              • 5864
              Ok.
              Yes, there is a difference in the crank dampner, the gap in the teeth are about 45 degrees different so you will need a VANOS crank dampner and pulley to complete the conversion. The Vanos plunger and intake cam is the only thing that different.
              • 303e30
                • Feb 2012
                • 71
                The m54 setup is under-square and the s50 is square, maybe that accounts for less power ? I bet the stroker has a flatter torque curve than a USs50 though.
                • Jib05
                  • Aug 2012
                  • 149
                  Its still a pretty good deal if you are looking at refreshing your motor before doing a swap I guess, but only if you get a good deal for it all. But then again in the US s50/s52 still looks to be a better deal.
                  .................................................. ...................sigpic
                  .................................................. ............................. ......M50B25 3.1L stroker
                  • tim12vgti
                    • Oct 2013
                    • 6
                    i recently bought a 92 touring with an almost identical build. M50 nv block with m54 pistons, rods and crank aswell as s52 cams. Vanos was added. It sounds great but its a heavy car and feels slow compaired to my vr6. Does anyone know a good place for tuning in south florida?
                    • The Dark Side of Will
                      • Jun 2010
                      • 2796
                      Originally posted by RobertK
                      M50 deck height is higher than a M54 so the best route on a 3.0l stroker build would be to have a machine shop deck the block a few mm.
                      Do you have the relative deck height numbers handy?
                        • Jun 2010
                        • 2796
                        OBTW: You need to get together with this guy:
                        • Kingb
                          • 928
                          Which trans and diff combo is in this car?
                          Originally posted by Nicademus
                          My car beats off to that car. :bow:
                          • RobertK
                            • Jun 2005
                            • 5864
                            http://www.r3vlimited.com/board/showthread.php?t=305953
                            Already a step ahead of that:
                            IIRC he has a G260 and 3.73 limited slip.
                            • Jib05
                              • Aug 2012
                              • 149
                              ^ I like that. Is that an m54 head? Also are you welding that adapter to the ITBs? My old levin had ITBs, miss that noise.
                              • Wishno87
                                • 6025
                                Any new developments on this?
