Hey, so I'm done with my swap but now I just need to figure out which of the flaps of the throttle body should I use? I'm using the S52 OBD2 manifold, it has the top flap which I assume is for cruise control.
Then on the bottom there are 2 more flaps, one top and one bottom, which one do I use?
Edit: just checked, the top one is for the traction control throttle body, and so I'm going to assume the bottom-most lever/flap thing is the cruise control, and the one on the bottom-top is the one the e34 cable hooks up to.
Edit: Also what sensor is that on the passenger side of the transmission?
