clash between intake elbow and E32 master cylinder
  • übersteuern
    • 45
    Hi, the latest project is to swap to an E32 booster and master cylinder (without the firewall spacer). I've never seen it mentioned here, but the small hose out the bottom of the M52's intake elbow (the ICV hose, I think) clashes with the E32 master cyl.
    What are the options for getting the ICV hose connection located further forward (relative to the car) on the intake elbow?
  • 328ijunkie
    • May 2007
    • 3961
    Which ICV line are you using? What Intake manifold and where is the ICV mounted? Its close but it should clear.
    Check Us out on Facebook
    Full Product Line Tuning
    • übersteuern
      • 45
      It's a stock euro M52 intake manifold. The ICV is mounted in the stock position (towards the rear of the intake).
      I'm not sure what you mean by "which ICV line"? Do the US elbows have more than one possible connection point? (similar to the 2 "breather ports" on this part?)
      Anyways, thanks to your hint, I have realised that a different shape hose joiner will allow the hose to clear the master cyl. Thanks!
